Sub enclosure for a pair of subs, shared or seperated chambers?
fo0manchu
Pros and Cons of both. Which one is prefered? I've always made boxes with shared space for both subs but have seen some box makers make seperate chambers. Will that cause cancellation of frequencies?? What do you guys think //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
with the shared chambers, I always put supports down the middle anyways, so the box wont flex. So how would you calculate the port dimension if you were using a shared chamber? And if the volume of seperated chambers was off, would that effect performance any?
PS: Congrats on 1,000 posts, kuijo
Thanks, i'll have to keep the posts useful so i don't give you any reason to take it away from me. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You would calculate it the same way as a single chamber, but you would subtract add the mass of two subs to your airspace, I believe. Someone please verify this to make sure im not making an idiot of myself //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif .
And yes, if you dont get the desired airspace, you wont get the exact same tuning... but how much of an audible difference it would make is questionable.
fo0manchu
fo0manchu
costa mesa
SSS 18734
