Sub Crossover point
efm80
what do most people here set their low-pass crossover point at on their amp or headunit too??? I played around with my headunit's LP and have had it at 80hz for awhile. Its next jump is to 125hz which I messed with today. On some stuff it really sounds good and brings in that mid bass sound, but some songs not so good. Is this high of a cutoff OK???
eddie
thats what I thought you meant but why wouldn't you want to "overlap"?? aren't you missing some of those frequencies??
eddie
nope. you can use crossover points sort of like a free EQ band.
if you cross the sub at 40hz/12db it's 12db quieter at 80hz. if you cross the mids at 80hz/12db they are 12db quieter at 40hz. thats how a crossover works. so right in the middle at 60hz both are 6db quieter. remember this is how they are crossed electrically, not acoustically. so it isn't a brick wall, it's a gradual slope.
in my install, if i cross both at 80hz then that area sounds to strong. so i created a slight half gap. all depends on the install and your preference.
great explanation! thanx
eddie
He is right, I assume you have a Pioneer HU (seeing 80/125hz xover).
I run my subs at 80 and my hpf at 125 for the best sound in my car. The area between 80 and 125 is still a little strong, but not awful.
exactly bro! have the Premier deck. thats what I'll set it out now. thanks man
I know of people crossing very low, like at 50-55 Hz. I guess it depends on your philosophy and the front system what your preferences are. I will try both low and around 80 when the times come.
efm80
efm80
las vegas,nv
helotaxi
vegang
vegang
