sub coil question (not related to impedence)
If you only use one coil you only have half of the BL product. In addition, Qes/Qts changes to a higher value. If you really must do that you should short the other coil. If you want to get crafty, you could use a resistor when shorting the other coil to adjust Qts.
slick327
slick327
Houston Texas
ciaonzo
