If shooting for SPL, should you maximize cone area for constant wattage?
spencer321
in other words, if your stuck with using X amount of power and want to reach the maximum SPL you can for given wattage is it all about mazimizing cone area assuming all other things are the same (sub and port direction, port area etc etc)
ex i can run 4-12's 2-15's or 1-18 but only have ~1800w
box size you have to work with also is a key factor
hey Rusty funny you should chime in the single 18 i was contemplating was a lvl 4xl
but i have enough space to run 4-12's 2-15's or 1-18, i want the maximum SPL for 1800w
Depends on a variety of things.
The install, the subs, the vehicle.
But I agree above that it is about efficiency.
again by efficiency your refering to total efficiency of the system, or the maximum spl per watt... thats what im trying to figure out how to figure out, is how to maximize efficiency (i thought the answer would be cone area)
Usually it would be cone area.
What kind of vehicle is this going in?
If you have limited power, you have to look at both power usage and cone area. If you have 1800 watts at your disposal, four 12's aren't going to do you any good if each of them needs 800 watts, but a pair of 15s would do pretty well.
i went from a single 12 to four lower rms subs and they walk all over my single sub...
Well no shit. That's 412sq of cone area versus 1256sq. You more than tripled your cone area. You'd have to majorly downgrade to have four tens quieter than one 12.
from what subs to what subs what wattage etc etc details as this is exactly what im wanting to do. I have a single HD3C 12 on ~1800 (its a hifonics 2k, so im guessing about 2k i know they are about 10% off)
and as far as vehicle I'm going to tell you the vehicle but DO NOT tell me "you don't have that much room" i know how to measure i don't give a rats *** whether you think i've got it... stay on the question at hand. Its a dodge ram standard cab i have 8 cubes gross and the port will be external so the net will be 8 cubes minus sub displacement.
i was thinking about 4 rsd 12's or the hifonics zeus 12's
spencer321
spencer321
palm bay
spencer321
