Sub box help
  • 2
Natebratt21
I have a system in a 10’ Dodge Charger that is made of 2 12 nvx nsw subs, and a ct sounds t-1000 amp. I am wanting to have it tuned to 32 hertz so i want it to be ported the dimensions I am working with are: Width 32 height 15. I am hoping someone can help me with a box plan since my box i have now does not go all the way back to my back seats since it is too tall. Thank you!
Nice... Incomplete parameters in manual... just use the recommended specs.. 36hz tuned box?... thats the recommend box?.. here's a quick and dirty 32hz box... single baffled, port on one end on same face as subs...easy low power box.
configured like this...
Thank you! I appreciate it!
Its slightly bigger than recommended... tuned lower... you might wanna go easy on the decaf... but sure... it should sound like a lower tuned box... better?.. its subjective...you asked for a 32hz tune... you tell me
Okay thanks again!
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Natebratt21
Natebratt21
Peoria il
Natebratt21
    May 16, 2024
    May 16, 2024
