Sold sub and headunit
austin39
dual xd1222 ill let it go for 40 shipped
http://i213.photobucket.com/albums/cc14/pntbllplyr14/Multimed-9.jpg
i have a alphasonik 12 inch sub with a rms of 700 and a peak of 1400 ill let it go for 60
http://i213.photobucket.com/albums/cc14/pntbllplyr14/Untitled-12.jpg
http://www.sonicelectronix.com/item_15820_Dual+XD1222.html
General Features:
In-dash AM/FM, CD player
Detachable face
Blue/black dot matrix type liquid crystal display
Blue button lighting
CEA-2006 compliant amplifier
Power Output:
Peak: 52 watts x 4 channels
RMS: 17 watts x 4 channels
1-year Manufacturer's warranty
Playback and Audio Features:
Playback of CD, CD-R, CD-RW
Tuner with 18FM/12AM presets
3-band parametric equalizer with 3 preset tone curves
Electronic volume, bass, treble, balance, fader
Loudness
Mute
Anti-shock mechanism
1 Bit D/A converter
8x Oversampling
Last position memory
Expandability Options:
1 Set of 2V preamp outputs (rear)
Front-panel auxiliary inputs: 3.5mm (headphone jack) allows connection to portable media devices such as MP3 players, etc.
Front-panel USB port is for charging only
http://www.sonicelectronix.com/item_2978_Alphasonik+PSW612.html
12” ALPHA 600 SERIES SUBWOOFER
Proprietary Cast Aluminum Alloy Machine Cut "Alpha" Basket
Proprietary Cooling Rings for Motor Assembly (Patent Pending)
Kevlar Reinforced Composite Balanced & Laminated Cone
High Tensile Strength Two-Layer Surround for Enhanced Control
Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
75 oz. Double Stack Magnet
Rated at 700 Watts RMS
88dB Efficiency
Frequency Response of 30Hz to 500Hz
Dual 4 ohm 2-1/2” Voice Coils
8-Gauge Lug-Lock Input Terminals
Mounting Dimensions — Depth: 164mm / 6-1/2”
Through Hole: 275mm / 10-7/8” Diameter: 312mm / 2-5/16”
1-year Sonic Electronix warranty
austin39
austin39
mexico ,ny
austin39
Mike Mccabe
