I'm looking at running an RE audio xxx 15 that is dual 4 ohm and I need an amp that will run true clean 2000 to 2500 rms at 2 ohms. Looking to spend 3 to 4 hundred shipped anyone got anything?
i dont think that amp will do 3k at 4 ohmslol You are comparing an Audiopipe amp to a DD Z1??? this amp at 14 volts runs at 4.6 ohms it will run 3000.... at 4.6 ohms!!! this amp will destroy the audiopipe amp. not to mention the z1 i'm only spending at the most another 300 more than that audiopipe amp and I'm getting a brand new amp that will on any day of the weak destroy your amp. not to mention its a much cleaner and more efficent amp!
lol go to ampguts it was bench tested to do a lil over 3k on 14.4 volts... at 4.6 ohms so.... just check it outi dont think that amp will do 3k at 4 ohms
Its funny you bring up the other amps. For instance the DDZ1A Digital designs refuses to rebuild.... also they were made in 2005. The amp I'm using was new in 2005 and used once. The owner of the amp by accident hit the pos + terminal on his battery bank with the RCA's and shorted out the amp. He never rebuilt it or sold it else where. When I send it in to Digital Designs It will Brand new when I get it back. Also the testing on the amp is what it is. These amps are proven to provide over 5000 rms @ 1 ohm on a 14.4 volt system. Also update I got the total price for shipping and repairs I will have only spent a grand total for a new z1 amp a total of $513.89 Tell me you can find me a true 5000 watts rms amp with the SQ AND EFFICIENCY of the Z1 for right at 500 dollars new shipped to my door? I have plenty of power with A big 3 upgrade a 15V system and batteries to boot. I have the power for that amp and plenty of know how. This amp being 4 years old is still one of the best around. The other amps are coming strong but the truth still matters is that at the end of the day they are running on 16V to get true power and need a lot of Power to run at full tilt. This amp is over 85% efficient at full tilt. That in itself is amazing and for the price I'm getting it I'd be an *Idiot* not to get it!!!I have to agree with quest51210!!! Not the idiot part, but Z1's are about 4 years old now. They have been replaced by the DDm3, the DDZ1a, DDm4 and the DDZ2LV!!! The Z1 was manufactered in 2005. You are going to pay a total of 700 dollars on an old azz amp that probably blown up several times before you got it or get it!! You would be better off buying an audiopipe amp or even a Sundownaudio 3000D for 650. Dude the Z1 is a relic of the past, dont do it.
The ampguts test was with a power supply that does not die down when they test it. The power supply that they use may give off up to 10,000 amps. The louder you play the amp, the more power (amps) they give the amp. And the voltage stays constant. That test was not real world testing. Real world testing is more like the 12 volt test. Dont make a mistake and buy it!!!//content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
