Sub amp geting HOT
07BronzeFuz
DueceEDuece
Guys, here is my setup
nine.4
nine.2
4 gauge power to distro to a fused distro 8 gauge to each amp
trunk of a 2007 Fusion
I just got 2 powerbase xtreme subs. They are d4 so I series 1 coil on each woofer and paral. the rest to amp to give it 4 ohm bridged. I am breaking the subs in a ported box volume about 13-15 playing different tracks. I have about a 30 min drive home. I stop about 20-25 mins after I started and I checked on the nine.2x. It was freaking HOT My nine.4 has got pretty warm before just powering the factory 6x8's but never like this. I just checked the seting on the amp and the guy that installed it at the time had the bass boost on and the gain probably a little more then half. It never clipped or cut out. Am I over reacting or do they normally run hot? I just dont want to mess up any thing.
turn bass off and adjust the settings from ur hu. it might be clipping a little also so back the gain down a tad. turn them down and if it doesnt heat up anymore then u know its the gains
yea I normally turn my hu to 20 to listen to music loud. I turned off the bass boost, and turned the gain down a little. Its probably under half.
Is that an A/b class amp...they tend to get warm especially if driven hard at minimum impedance's
I wired the subs to 4 ohms. I am sure of that, I dont think the amp would of lasted at 1 ohm bridged. I turned the gain to about half and backed it off a little. The amp is in such a bad location I had to unbolt it from the false wall its on. Its a pain in the butt to check.
i remember my older rf power series amps getting pretty hot also.
07BronzeFuz
DueceEDuece
07BronzeFuz
Nashville North Carolina
07BronzeFuz
