Sub/Amp decision help
  • Thread starter Decifer
  • Replies 0
  • Views 725
Decifer
I am going to be making my first fiberglass enclosure but I am unsure right now what Sub/subs and amp I should use from what I have and need a little help and advice. The vehicle is a 96 Silverado extended cab , the enclosure will be going underneath the rear set. The head unit is a Pioneer deh-5800 and also will be adding and audio control three.1 EQ. Now the part I need some advice on is what subs/ amp to use. I currently own 2x JL 12w1. (single voice coil 4ohm) and 1x JL 12w3 (dual voice coil 4ohm)and also 2x 12" MTX thunder 7500 (single voice coil 4ohm) For amplifiers I have a JL 300/1 and also an old Lanzar Optidrive 2200 , I estimate the have @ 3 cubic ft. of space to work with . I listen to mostly rock and metal Any advice on what sub/subs to use and with what amp or and advice in general would be greatly appreciated.
Decifer
Decifer
Pilly , PA
Decifer
