stupid question...taping wires
VTLexus
I am trying to install an aftermarket sub/amp into my IS350. ive used the lexus forums to basically figure out the wiring. people keep referring to tapping into wires. i know i can splice the wire and solder to and that will tap it. is this the only/best way to do it? any other ways to tap into wires?
I solder everything. Peace of mind, but sometimes you just cant solder wires because of location so I use these:
with these:
You can also use scotchloks:
But again, soldering is the best way to make connections.
Dont use the scotch locks those are pretty crappy.
If you are using t-taps, the first picture, you can just strip a small portion of the jacket back and clamp the t-tap on the wire with pliers. Than use the male spade, second pic and plug it into the t-tap after you have crimped the spade on the wire you are adding into the circuit.
You can also do what is called a wire knot. This is very similar to the soldering method without using a soldering iron. You strip back a little of wire in the middle of the run. Stick your pick through the wire and then insert 2-3 inches of the wire into the hole you made with the pick tool. Than wrap the wire around the other wire and tape or heat shrink the wire.
VTLexus
VTLexus
Herndon, VA
avs20
