reed dollaz 10+ year member CarAudio.com Veteran 2,818 0 Ocala, FL Oct 13, 2007 #1 the 12" Icon im getting is dual 1ohm. if i wire in series, will it be 2 or 4 ohms? Click to read more...
Safe-N-Sound215 10+ year member Kenzo 4,083 0 Philly/VA Oct 13, 2007 #2 2 ohms. Series doubles, parallel halfs.
OP reed dollaz 10+ year member CarAudio.com Veteran 2,818 0 Ocala, FL Oct 13, 2007 Thread Starter #3 2 ohms Click to expand... well i was going to get a kicker zx1000.1 to power the 12" but i think i might as well go with the package deal and get the SAE-1000D w/ the 12
nismos14 5,000+ posts CarAudio.com Veteran 14,812 4 Jersey Oct 13, 2007 #4 the 12" Icon im getting is dual 1ohm. if i wire in series, will it be 2 or 4 ohms? Click to expand... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif dual 1 ohm with one sub will never be 4 ohms.
F Fear Of Theive 10+ year member CarAudio.com Veteran 2,209 0 Pittsburgh,Akron Ohio Oct 13, 2007 #5 ygpm
soundsolutions Pro Seller SoundSolutionsAudio.com 1,468 48 Potsdam, NY Oct 14, 2007 #6 if you go with a single sub set up, you'll want to get to a 1ohm load mono, so you'll need a dual 2ohm ICON, if you go with a pair, you'll need a set of dual 1's to get to 1ohm
