strapping stereo amps
gotparts90
class ab full range stereo amps. Can it be done some way? I was looking into the hifonics device to try and I just want to know any other options. I was thinking 1 amp per coil on a DVC speaker and balance the output as equal as I can get it with my meter but that seems like asking for trouble. I want to maybe put both my arc 2500cxl amps on one speaker like a critical mass ul12.
Ideas would be a great help thanks.
no, you cannot strap 2) 2 ch stereo amps together.
But you certainly can put one on each coil of a DVC sub. Just match the gains as best as possible.
I knew i could not strap them like mono amps but just was thinking that one on each coil may be a bad idea.
If its cool like you say I may try it. I may give it a go one sub would keep the weight down in the car a bit. I just hate blowing stuff up and would rather check stuff out first if I never tried an idea before.
yeah I know a large amp is better but I bought one and the day after I got laid off it got shipped to the building next to where I worked at and S Garcia got it and i never saw it since.
maxx link is one thing i was looking at but two subs is how I have run like this before or 12 subs on six amps. I want to go down to one bigger sub. I am going to put one amp one each coil of a bigger sub and give that a whirl. I have a clarion crossover with a bass knob (thanks turd) I will use to adjust it after I have set the gains and matched them the best I can.
thanks for your help ed just want to make sure I don't blow anything up.
gotparts90
gotparts90
chicago
gotparts90
michigan born
    May 14, 2026
michigan born
    May 14, 2026
