Stop me if I am wrong!
Screws it its! Do the plans look ok? I did some search and that came up for 1 Type R 12" I think!
make sure you pre-drill. do you have clamps or is someone gonna hold the pieces together for you? what i used to do when i used screws was get 2 drills, and then my cordless which doesn't have a lot of balls would be used for the pilot hole, then i get the electric one to drive the screws in. also you could use gorrilla glue if your cuts aren't totally accurate.
clamps + glue;)
Not everybody has big enough clamps, or the //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif to go buy as many as necessary.
But almost everybody has a drill and some drill bits //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lets get all the info into one post
  • MDF
  • 1" 5/8" Corse Drywall screws
  • GLUE: TITEBOND II OR GORILA GLUE
  • CLEAR SILICONE CAULK
  • CLAMPS IF YOU HAVE THEM 36", 24", RIGHT ANGLE AS WELL
  • CIRCULAR SAW
  • DRILL
  • ROUTER OR JIGSAW TO CUT YOUR MOUNTING WHOLE
  • SAND PAPER TO SMOOTH YOUR OVERLAPS IF CUTS ARE OFF.
  • MAKE SURE YOU PREDRILL ALL SCREWS BEFORE SCREWING THEM IN OTHER WISE YOU'RE LIKLEY TO SPLIT THE WOOD.
  • MAKE SURE ALL SCREWS ARE COUNTERSUNK ( NOT NECCESARY BUT MAKES IT LOOK GOOD WHEN U CAN FILL EM IN AND THEN SMOOTH IT OUT WITH SAND PAPER //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
  • OH AND MEASURE 2 TIMES AND CUT ONCE //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Bam!//content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif//content.invisioncic.com/y282845/emoticons/yourock.gif.93d527d504392657a77fa577298070a1.gif//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
That sums it all up!
looks like 2.15 cubes tuned to 32 hz with 27sqin of port area
or atleast that is what the filename for it is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
~Magick_Man~
Raffi
Bring our TROOPS HOME!!!!
Raffi
Orlando, Florida
Raffi
