Stock wiring + New wiring (speakers)
wildebeest
I have a 1992 honda accord and I'm wiring comps to the front doors. I managed to squeeze the crossover in the door, so to save on wiring, it would be really nice to splice into the stock speaker wiring to the door and avoid the molex nightmare. I was wondering if there's any performance concern.
--15feet of 16ga wire from amp (150W x 2) for each side
--Linked to the stock wiring behind the radio with butt connectors (I'd guess 20ga?)
--20ga from the crossover to the components
Are there any things to worry about here?
If your going to add an amp, you'll need to run new speaker wire. You could just use the factory wiring but it may be to small for the power the amp is putting out. I understand not wanting to deal with the Molex, but if you want it done right do it right.
you really should go with 16 gauge all the way. (14 gauge is optimal for power levels over 100 watts per channel) especially over a longer run like speaker wires.
you're losing roughly 30% power which will mostly show up in your lower end. 20 gauge has a 8 amp capacity while 16 has a 20 amp capacity over a short run (these values get smaller over distances of 4+ feet) I understand it's a pita to get wires through the doors, but in the long run your ears will thank you.
wildebeest
wildebeest
Oregon
Radioflyer97
