2006 Honda Pilot w/NAVI wiring harness
HvNd4Speed
what im looking for is not a standard wiring harness, i can find that anywhere online for 10 bucks
I want to add an amplifier to my stock setup, do they make a custom harness that is plug n play that can hook up the power to the deck but speaker wires open to hook up to a Navone LOC for example.
the reason for all this, I dont want to splice/cut wires behind the OEM head unit in case i ever want to sell, what a mess that would be to clean up!
so im looking for an integration like what i mentioned....i have searched to find nothing, there has to got to be a solution
actually, modding the factory harness isn't that much of a mess if it is done right, find the speaker wires (which in a honda are easy) and just strip away some of the insulation - poke a hole through the wire and insert the LOC input wire, squeeze shut, wrap input wire around stock wire and solder. When It comes time to remove it to sell, just cut the input wire leaving about an inch pigtail and put a crimp cap on it.
HvNd4Speed
HvNd4Speed
So Cal
starkfu
