Xenozx
OK, so I have a 2010 Mitsu Evo, and it is a 9 speaker system running at 2.5 ohm w/ 1 10 inch sub. the stock head unit does offer independant sub control, which is kinda kool and may make it worth while. Heres what I want to do, and I was hoping someone could tell me what I would need to make it possible?
I want to keep the stock headunit for now.
I want to add a 10 inch W6 and remove the stock subwoofer.
I want to use the signal wire that currently goes to the stock sub, and use it on the W6.
I believe I will need to use something to remove the amplified signal from it, so that it is signal only. What would I need to do this?
Is this a feasable situation?
