Stock S-10 HU
The stock radio is DIN and 1/2 but in the 96 there's a factory pocket attached to the bottom of the radio, so the actual opening on the dash panel is quite a bit larger. On the other hand, there's also a depth issue to worry about on these vehicles; the factory radio isn't as deep as a standard aftermarket head unit.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
531
751
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
489
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
620
OneKrazyKeebler
JUST ME
OneKrazyKeebler
Mt. Juliet, TN
Hintzyboy
    May 24, 2024
