Stinger Sound Dampener.
looks thin
Uh, you can tell from the pic? Come on. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif According to the specs its 80mil thick with a 15mil aluminum constraining layer. Over all product thickness does not tell us density (or material type/properties), but if that alum layer spec is correct, its far thicker than anything SS has that Im aware of.
Well one thing I'm just a little nervous about weight on my tailgate.
The cmopany that makes Road Kill for Stinger is decent.
The product is actually 70 mils thick with a 4 mil foil.
Not 15 mils
The 6 mil, high temper foil on Damplifier Pro is 50% thicker, and a good deal stronger too.
Plus the Damplifier Pro is 80 mils thick.
ANT
The cmopany that makes Road Kill for Stinger is decent.The product is actually 70 mils thick with a 4 mil foil.
Not 15 mils
ANT
That ad definitely says 15mil alum layer. But your number sounds much more believable (and I suspect either you or Don actually measured it).
ANTThat ad definitely says 15mil alum layer. But your number sounds much more believable (and I suspect either you or Don actually measured it).
True, but that is an ad for a vendor
Go to the AAMPofAmerica.com stinger page. 4 mil foil
I have taken measurements, and the foil does come in at 4 mils, but the butyl is 70
ANT
I'm more thinking price wise.. is it comparable to regular damplifier?
Price?
A 20 sq foot pack of Damplifier is $59.98
In terms of performance, it will be close
Damplifier is designed to outperform most of the better competitors out there while weighing less.
It does a good job against most quality damping mats.
Even though Damplifier is our entry level material, the foil is still just as thick as the foil on Damplifier Pro; 6 mils thick.
Since the foil does so much of the damping performance, it does not require as much adhesive to do its job.
ANT
get liquid spray dampener i have found cascade way better than any peel and stick dampener. it goes everywhere were the p & s cant too. you can do layers and make it thick where needed...
Price?A 20 sq foot pack of Damplifier is $59.98
ANT
It ends up being the same because they're both 75 shipped.
Spray-on deadeners tend to be better mass loaders, due to ease of total coverage, but the mats are definitely a superior product in almost every other way (performance-wise). Spray-ons do not have a constraining layer, for example.
Dats y eye use both... along wit egg foam behind the door speakers...
MONSONwarrior
Premium Member
Constantly Rebuilding...
MONSONwarrior
Baton Rouge, LA
audioholic
vegang
vegang
