stinger batteries
would 1 battery be sufficent for a 1200w rms system with a tiny 70a alternator?
if so, pm me and ill buy it right now
if in addition to your 70 amp alt
if you also have
suffcient under hood battery
big three done in 1/0
and 1/0 awg power and ground from under hood to trunk then you should be okay
but take 2 and you will be super good
lmk
Specifications
Internal resistance 7 mOhms
5 Second Cranking 680A
Short circuit current 1800A
Weight 15.4 lbs
Temperature range -40 C to + 60 C
Deep Cycling Ability
Average capacity withdrawn Typical life cycles
100% 400
50% 800
30% 1450
10% 4000
The shallower the discharge the longer the life.
Never discharge battery below 10 volts
or let battery sit in a discharged state.
Dimensions
6.67” H x 3.11 ” W x 7.27" D
Add 5/8" to height for battery post
350zspl
350zspl
WPB Florida
350zspl
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
