STILL F***ing up. Im literally going to light my sh** on fire!!!
someone from the forum, I know there's a bunch of people in florida
the voltage is 14v while it goes into protect or right before/after. Does it stay in protect or only come back on when you turn it down
it sounds like you are clipping. when the car is turned on, and the sub is at or around 35 is the voltage still at 14?
well the clipping indicator doesnt turn on on the bass knob, but for your question, its a little less...
sorry, I just don't want to blab when I honestly don't know...
Did you set the gains properly? Only experience I have ever had with an amp going into protect was a blown sub once and then a voltage drop once...
its ok, i dont blame you for not knowing lol, but dj told me where to set the gain
check the wiring on the sub terminals, maybe it could be that you didnt have a good connection and only one VC is hooked up
ok, just wondering, to wire a d2 sub to one ohm, you take a wire and connect the + to the + then another wire - to -. then you take the positive and negative of one terminal dock and connect it to the amp....???
when it goes into protect i have to turn the radio off then on again. its ****ing annoying
yeah, i believe that would be the way
thericanballer
God Bless You
thericanballer
Orlando, FL
themgators511
