stetsom 7kd vulcan
Stetsoms are cheaper then that if you are a World Class competitor. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll just stick with what I got though.
id love to see the tests against other 7-8k amps. Instead there all comparing it to 5k's because of the size difference and not the ratings :shakeshead: Im sure you could get a sampson for cheaper than the retail cost //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Id take a zenon built board over a maxxsonic or stetsom amp anyday //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif But thats just me. BTW, from all the test results ive seen yet to date theyre all different in terms of efficiency and wattage so who to believe? theres lots of hype on them now just like the 40.1 when that came out, and we all now what the 40.1 can do :rollseyes: and that aint no joke or was it?
there good amps..from talking his only rep in us they do there rated power at 12volts...
80
Im sure they do //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif the amps are rated at 13.8 volts this rep isnt the same guy who is flooding stetsom on termpro is it??
Channels: 1
RMS Power @ 13.8V
Mono 1 Ohm: 7000 Watts
Mono 2 Ohms: 4500 Watts
Mono 4 Ohms: 2400 Watts
RMS Power @ 12.6V
Mono 1 Ohm: 5200 Watts
Mono 2 Ohms: 4300 Watts
Mono 4 Ohms: 2100 Watts
Minimal Input Impedance: 0,2V
Total Harmonic Distortion:
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 a 15 KHz
Frequency Response: (FULL RANGE) 20 Hz a 15 KHz (-3dB)
Input Tension: 9 a 16V
Power Consumption: 6 a 480 A
Dimensions: 70 x 280 x 660 mm
weight: 10,0 Kg.
where could you find a sampson for cheaper, also i need a hookup on cactus sounds, because im going to buy a bit of them, of the 7k's, and if ic ant get them cheap enough stetsoms for the price, you cannot beat. i would love to run the sampsons though but the price makes me not want to even consider them.
i can get a 7k from cactus for about 1600-1700 and i like their prodcuts, i love the sampsons, just the look of them. but the stetsoms have the vote with the price and their rated at 13.8. thats pretty good
cactus aint cheap its a toss up between the stetsom and cs 5kw for the rex
wait till I show some pics tomorrow night whats going into my rex //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
You would need 10kw to be up 3dB from 5kw even in theory. You should be up about 1.2 dB ideally going from 5kw to 7kw... so where is the complaint about gaining 0.9 dB in the real world? Seems like a very solid gain that fits the power increase darn near on the dot.
I agree and was actually going to say essentially the same thing.
I came up with a "theoretical" difference of 1.46db, just a smidge higher than 1.2db....but nevertheless I completely agree that only being ~.5db "in the real world" behind the theoretical difference, at those power levels, is quite a significant increase.
I wanna talk to SAMSON, fly me to the moon I command ya!
LOL...ok I just wanted to subscribe :p Anyone got a pic of these stetsom amps? Was just reading at termpro and team stetsom hit 179.7?!? WOW!
Im pretty sure mr. dante could hit that number with any stout 7k amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Install/enclosure has alot to do with it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Hes not gettin that # just because hes using stetsoms. Just my oppinion.
egg
matrxx dude (John) has 2 of them in his Street C Explorer. Theres a picture or two of them on floridaspl.com in the Dublin 3x album and a couple of them in his db drag link I think.
they are bad arse,i got 2 of them on 4 12 mt's,154.9,and as far as maxxsonics fixing amps in a timley manner,they dont,they have had a cyclops of our store for repair going on 6 months now,and another point like a couple already said .9 db from 5k to 7k is dam good,i trust alan and why not he is the loudest guy in the world,or his builds is.
SplChoice-
Weez.
SplChoice-
Oak Hills, CALI
pioneerpimp
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
