stero integrity single 15". help needed
turboed331
because of my roll cage im confined to a 2.3cuft sealed enclosure rear firing setup. my ? is can the mag 15" ran @ 1ohm and 1100rms in that internal volume sound good. i was told 2.5cuft would be best but i just can squeeze it in. how far off the range will i be for the best frequency. i heard 80hz is where i wanna be. im about 8" away from the rear of the trunk and the car is completely sound proofed. i guess my ? is will this car pound with this setup my amp is the memphis belle. thanks for any help
That difference will be practically inaudible in a sealed enclosure. It's a difference of less than 9%, and driver parameters often vary by that much during a production run anyways.
80 Hz as in... the low-pass filter? That's going to depend on your individual setup. In general, 80 Hz is a good starting point, but you can adjust up or down from there depending on what sounds best to you.
As far as whether or not it will 'pound'... we don't have a freakin' clue -- the best we can say is 'it should'. Put it in the box, hook it up, set your gains, and let us know whether it does or not
2.3 should be fine for the mag sealed, just add a pound of two of poly fill and you should be fine. 80hz is ok if you are not running active and can control your front stages frequencies. I had the mag in 2.5 sealed in my trunk and the output was not bad at all but, if you want to get loud get a port bro ham.
turboed331
turboed331
buffalo ny
Ptown_TSxxx
