Stereo-Mono Operation
DJGTSR
Hey,
I have 3 10W7s, I want to hook it up so I have one on each channel and the other bridged on both channels.
What would the overall impedance be on the amp and what would the woofers see? Would they be equal in the power they recieve?
J
2 channel amp.
1 10W7 on right
1 10W7 on left
1 10W7 bridged on both channels.
I need to know the resultant impedances to make sure my amp can handle it before I hook it up.
I also need to know the proportional power that the subs get.
J
W7s are SVC. The amp is a USA-400 (22 incher from usamps). It can handle this sort of operation, Ive read in the manual //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im just confused on how to calculate impedance loads for Stereo-Mono...
J
amp specs
USA-400 Only
One Ohm Stable
50 Watts x 2 into 4 Ohms
66 Watts x 2 into 3 Ohms
100 Watts x 2 into 2 Ohms
200 Watts x 2 into 1 Ohms
200 Watts Bridged into 4 Ohms
264 Watts Bridged into 3 Ohms
400 Watts Bridged into 2 Ohms
amp specsUSA-400 Only
One Ohm Stable
hook 3 3ohm SVC subs together in parallel for a 1 ohm load.
The amp is not stable in 1 ohms bridged. Actually the amp im getting is an X series, so its actually only 2 ohm stable per channel.
Ill be back in a bit to discuss, i need to figure this out but i have class now,
J
okay, not so old school specs
Two Ohm Stable
100 Watts x 2 into 4 Ohms
132 Watts x 2 into 3 Ohms
200 Watts x 2 into 2 Ohms
400 Watts Bridged into 4 Ohms
i dunno, i can't come up with a decent scheme. If the manual says you can do it, then I guess you're good....that's with 3 ohm loads???//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
okay, not so old school specsTwo Ohm Stable
Old school specs on the USA-400 ( 1 ohm stable ) are:
200 X 2 at 4ohm
400 X 2 at 2ohms
400 bridged into 8 ohms
800 bridged into 4 ohms.
Im hoping that for the USA 400X the specs get bumped up to 400X2 at four ohms.
J
In theory, you would be running 1 ohm per channel final load (same as bridged @ 2 ohm). The left and right subs would be getting a paltry 267 watts each and the center would be getting 1067W. Result will be a ton of cancellation and a crappy sound. That is WAY the wrong amp for 3 of those subs. You would probably get better sound from just one sub on that amp than the 3 wired as you propose if you are dead set on that amp. If the amp is not a done deal and you have the subs, find a better amp for the job, preferrably one that can handle a 1 ohm mono load and put out a good amount of power.
And IIRC the difference between the 400 and the 400X is a built in crossover not more power.
DJGTSR
DJGTSR
US of A
myvanpounds
