staticy channel at low volumes
ragefan2k
ct
I have a 240 watt sherwood amp for my high's the prolem is , is one of the channels is staticy and liek doesnt work at all when the volume is low , but on high volume it sounds fine .... any suggestions on what it could be .... loose solder joint or is it something more serious
104
351
10
732
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
432
ragefan2k
ragefan2k
ct
MikeofTulsa
    May 31, 2024
    May 24, 2024
