Static from Pioneer x3700bhs
  • 2
logic227
I'm pretty sure my radio is producing a small static to my speakers. It sounds like I'm using a cheap bluetooth adaptor, but I'm using usb. I hooked up a kenwood radio just to try it and the static went away on my rear speakers, but the fronts still played the same sound. The radio wasn't powered to my amp. Could it be the radio harness? It's a Scosche. I just purchased a Metra to see if that would do the trick..
Pioneer has had a pico fuse issue for years
I would ground the rcas unless they fixed it with the newer models
That may be it but static can be hard to pin point
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
885
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
logic227
logic227
New Jersey
tymoto21
    May 18, 2024
    May 16, 2024
