Starting on Kick Panels
squeak12
I just taped my driver side off. Im about to tape off the passenger side and try to get the mold set up before dark. I have about 1.5 - 2.0 hours to do this in. Its going to house my 6.5 MB Quart Premium Mids. Ill have some pictures up later for criticisms, etc.
PICTURES
It was too dark to get pictures of the molds which are curing, though.
Ok, I got them extended up some, just not a lot. The driver side can only go up so far though because of the E-brake pedal. About how many layers should I do before its able to be pulled out. I just checked and the driver side is pretty dry and the passenger side is almost dry.
my brother looks like your going to have trouble aiming them correctly with the reliefs you have there.
Try this
tape up your entire area like your getting ready to glass
start with your rings or baffle ,Which ever you choose
And start the aiming process using wooden dowels and hot glue. Once you get the aiming and positioning right. Then outline the area for your relief casts ( backer plates ) and also mark your dowel positions on the tape as well. Then layup a couple layers of mat. Once dry you can transfer your marks from the tape to the glass itself. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
squeak12
squeak12
Thomaston, GA
squeak12
michigan born
    May 14, 2026
michigan born
    May 14, 2026
