Starting DJ buisness,advice 4 equipment
You are too novice to the audio field to be designing PA systems and charging money to play them at weddings and the like.
Pro audio is not that easy. Getting sound quality out of a cluster like that will not be fun either.
Get something tried and true. B&W_EE on here has YEARS of experience in the world of pro audio. I don't know how willing he is to help, but he's definately going to be a good place to start.
I was wondering when someone was going to say something along those lines.
Honestly, I built a set of speakers very, very similar to these and I think they'd work well for what you want to do:
http://www.partsexpress.com/projectshowcase/magna/index.html
They will fill a High School cafeteria, and an auxiliary gym. I've only DJ'd at a couple local high schools and a few house parties, so I don't know how well they would do at a larger venue with high ceilings, such as a union hall.
In smaller venues, they don't need a subwoofer, and I'm just powering them with a 100x2 Pioneer Elite amp.
I never found out what happened with the guy who was selling a pair of K-horns, La Scalas, and Cornwall II's about an hour from me.
Think he sold all of them though, they were minty //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Da taada da.... I'm here to direct the TARDS lol.....
First of all..... DIY PA is harder than DIY home.... For several reasons. First off let me ask some simple easy to understand questions for all the little kiddies out here....
1. How much are you getting paid?
2. How many people are you going to be covering?
3. Where do you live? (This affects the type of music you will be listening to)
4. Will these be "upscale" events or "back yard" deals?
5. How often are you going to be moving this stuff around?
Ok, so why do I ask the questions I ask? You have to factor into how much you are making for the budget you spend on your PA. If you make 15k a year you wouldn’t buy a 50k PA like a curvilinear line array with subs. Second, if you are going to be covering 20 people you don’t need as many boxes as you would if you were covering 200 people. That said no two jobs are going to be the same so you want the system to be build able, meaning for one job you might use 2 high boxes a side and a sub, but for another job you might only use 1 high box a side and no sub. There is no point in dragging PA out that you don’t need to use. Third, if you are going to be playing rock and roll dual front loaded 18”s, stupid wedding music 15” 18” hybrid box, rap you need more subs. The Pro Audio and sound reinforcement world is completely different that the car audio world. I know you said that thing about using car audio drivers, DON’T. PA drivers are made for PA applications; car audio drivers are made for that application. Think of it this way, a PA driver that weighs 15lbs vs. a car audio driver that weighs 50lbs now put it in a box that weighs 50lbs. Which would you want to move if you had two drivers in that box? I know that everyone on here is strong into the DIY, but for Pro-Audio to do it right I wouldn’t even touch DIY. You need something with a good strong horn and a good 12” for your top box. You want something with a solid dispersion pattern around 60x40. (DIY you would never be able to match that 12” and the horn). Subwoofer wise, depending on your needs I would say either a sub with two 18’s or a 15 and a 18. I will post some links for you to look at later today.
But, I am also throwing this warning out to you. There is a lot more equipment that you need than you think. You are going to need a mixer that is good first off, wireless mics are not cheap, I would get two compressor/limiters for the mics, and EQ between the mixer and the speakers with decent processing in it, all your necessary cables, including correct power. If you go unpowered you will need to get processors if you go powered cabinets they will be more money….
I will send you some links….. Good luck is all I got for you…. It’s not as easy as you think…
Also, what are you going to be playing the music to the system with? If it’s a laptop think again unless you want a really good mixer and a few DI’s in-between.
1. $500 per pary for 5hrs average , otherwise $1100 for upscale
2. usually 250 people up to maybe 400
3.I live in TX, but the type of music will most likely be Cultural(Indian,Hindi, and Panjabi type music ,the panjbi music is dance..
4. event are held in an banquet hall,like Anatole or Intercontinental
5. moving around for different events, so setep is required for each event.
Ok.... Well decent money.... So, let me put some stuff together for you....
Basically EV, JBL, or Yorkville Speakers
Behringer, Yamaha, or Such for Mixer
Senheiser or Shure wireless on mics
Tascam CD/Tape Player
Behringer or Ashly Audio comps and prsc
Unpowered Speakers.... QSC Amps all the way....
Some of this stuff you can find on sound broker for ultra cheap...
I'll lay it out for you.... Just give me sometime. I got nothing better to do lol....
thanks but i got to weddings to do the video also, and i noticed most of the Dj's have way too much bass and not enough clarity coming from the speakers. and i dont really ike the sound JBl puts out
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
joetama
