SSA Demon (10" & 12")
This sanded pine you use?
https://www.homedepot.com/p/3-4-in-x-4-ft-x-4-ft-BC-Sanded-Pine-Plywood-1502208/205999854
Seems like there is one that is 3/4 and the Common is .703.
Thats the 7 layers one. Try to find 11 layered if you can, otherwise thats fine too.
Sub was delivered no issues. Built like a tank. The outer box does have SSA Audio wording on it so not discreet. Luckily my UPS person knows not to leave stuff at the door but over my patio wall.
What is the sub displacement for the 12'?
Anything Mac friendly for designing a box?
I got a new piece of 4" pvc so will use that for the port to keep things simple. Heat gun to flare the ends.
Displacement of 0.16 ft^3.  I believe sketch up has a mac version.
2.10cf @ 33hz
Little rough around the sub on the second baffle so used some caulk to clean it up. More work around the port, some paint and fill screw holes. Be a few days before I fire it up. Last time I make a box using a circular saw and jigsaw too much of a pain. Weighs almost 60lbs by itself. Sub is 25lbs. Used MDF I had on hand.
Sub sounds great. Box is perfect for rap. Metal sounds good also but wouldn't mind a little more kick drum boom. I'm going to experiment same airspace with a higher tune with a Aero. Or should I increase airspace and tuning? Is one 4" aero enough for this sub?
Just experimenting. Never tuned this low and used a slot port. Now I have an idea of what it’s about. Now I need to know what the rule of thumb is as far as how many round ports and what diameter is needed for a certain airspace and power.  I know some people say you don’t need as much port area vs a slot and some say you do.
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
denim
SSAudio.com
denim
SSA HQ East
2RZ-FE
SPLBassJunkie
    May 21, 2024
    May 20, 2024
