king ranch
Banned
whyIn the last year I have had no less than 10 boxes that I and the DFW crew have built. I will never do another slot port EVER
Always used PSPhow do you flare the pvc and is there any difference in using pvc compared to psp ports
refer to post aboveWhy is that? port noise? Tuning issues? Please enlighten me...
Which means nothing in a daily box.yes it does. a round port has the best perimeter vs. area ratio.
True I should have stated regular pvc.aero's are way more efficent
so you are saying aeroport wont work with this subI always use box notes and winISD.
Kicker recommends slot ports.
Sometimes I use this. http://www.subwoofertools.com/forum/ported-box.asp
The x-mas determines the port width for that calculator.
This will be install dependent. Also you wont use as much area for an aero port as you will a slot port.is aero louder
and that makes no sense u said aeros have less port noise and sound better
Where Did you get that notion from?...........so you are saying aeroport wont work with this sub
i find that hard to believe
