SQ system suggestions
The Aura looks fairly deep- could be a problem, the focal however, i really like- will look into it.. any more suggestions from anyone? or component suggestions?
The Aura 10" sub is 178mm deep, that is 7 inches (25.4mm per inch iirc). You should be able to fit that I would think?
But yeah, the Focal looks nice too //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
well what do you need? hu, amps, speakers, subs? plan on using outboard processor or use the HU's abilities? plan on going passive or active? how many amps would you want to run? need rear fill?
on another note, i'd take a pair or even a trio of the aura ns10's.
first post friend-
Going to use the factory head (factory nav, etc) And thinking of going with the memphis belle amp (the bigger one) I need sub and speaker suggestions.
speakers, sub suggestions is all i need the aura comment is noted, though! any more?
Only problem is that the gas tank is behing the back seat, i believe, so im thinking 1-2 10's in the back deck... (maybe a flat sub) So- fire off the suggestions!
Could you do IB using a manifold and thus open up your options quite a bit?
first post friend-Going to use the factory head (factory nav, etc) And thinking of going with the memphis belle amp (the bigger one) I need sub and speaker suggestions.
are you going to be running a cleansweep or something?
Probably a rockford 360.... as far as an IB setup- ive never tried it, but would be willing to try...
Post up some trunk pictures and give us some idea of the trunk dimensions (height, width, etc). I'm guessing you've got some room to work with.
02parkave
Banned
02parkave
Oklahoma City, Oklahoma
envengineer
