Buffalohed
Music Snob Extraordinare
I've read through almost every single "SQ" or "SQL" thread in this forum trying to get a grasp on everything. I keep running into some common themes that are really bothering me though. First because there seems to be a lot of disagreement on them, and second because they seem totally contradictory.
1) Sound Quality. When I think of sound quality, I think of tonal accuracy. Does it really need to be more complicated than this? "Sound quality is subjective" I keep seeing. Is it? Obviously "I think this sub sounds good" is a subjective statement, but tonal accuracy is not a matter of subjectivity. So what exactly about a SQ subwoofer is subjective? Opinions?
2) Install (AS IT RELATES TO A SUBWOOFER). I see over and over again, "SQ is 90% install" and hundreds of similar comments (referring to subwoofer SQ). I need clarification on this, because afaik install consists of A) enclosure, B) amplification, C) components, D) soundproofing, E) car acoustics. In a discussion about the SQ (tonal accuracy) of a subwoofer, shouldn't it be a given that the C) D) and E) are the same? Why would you compare Sub A in a car with 5000$ of audiophile equipment setup to Sub B in a banger with a stock system? All of this nonsense (it seems nonsense to me when someone says that) would indicate that the actual subwoofer has very little to do with how good a subsystem sounds, which doesn't make any sense to me.
So here is what I am asking. Is there really anything more to the install than how you are powering your sub and how it is enclosed? Also, how difficult/complicated is it to use the manufacturers enclosure recommendation? I would assume that if you want SQ and follow the mfct. rec. for a sealed box you would have that part of install covered, then you give it nominal RMS and you have amplification covered. Equalization, crossover (both clearly important for good SQ), all of that is based on your components and how you tune your system, but it doesn't really play a part when comparing different subwoofers.
To simplify: Sub A properly amped, properly enclosed, and with specific components vs. Sub B properly amped, enclosed, and with same components, should be easily comparable, right? It seems like when someone says "SQ is install dependent" that is referring to the fact that if you screw it up or don't do something correctly it will sound bad, but assuming proper setup that phrase is meaningless. Am I missing something here?
3) SQL. I'm not sure what the concensus on this term is, and I don't really care. It is very meaningful to me. When I am seeking SQL, I mean SQ able to extend to higher volumes. I don't think of it as a mix between good SQ and SPL. I want the best SQ possible, but loud. What is so difficult to understand about this? Again I am either missing something, or people are using a different definition of SQL.
Now to give some background. I am searching for a SQ setup for my car that can get very loud, because sometimes I feel like blasting my music, but extremely accurate reproduction is of utmost importance. I am trying to decide between Aura 12's, Nobelium 12's, and possibly IDMax or Mag 15s. If anyone has a suggestion I would love to hear it.
Sorry if this post seems abrasive, but I am looking for some real answers to replace the countless anecdotal snippets I have come across here. I've become very good friends with the search feature here, but sometimes it isn't the best tool, so I apologize if this thread is a repeat.
