sq amps
Well, about the only usefull input I can make is that I was not aware that cadence was ever known for SQ. Those other two are nice amps, but I don't know if you'd really notice a difference between them and your current amp.
well I got 4 mb quart discus speakers. i will go active just waiting for he imprint processor to come out for the 9886. You got any suggestion for amps under $350
any of the amps you listed will be fine. They are all disgustingly under rated.
There are also some much cheaper choices that i am sure will do you fine and will last forever if you set the gains correctly and dont have electrical problems.
you need to qualify that about 10 different ways before you get torched.
amplifiers should just simply be amplifying the signal, not changing the signal in any way. so given to amps have the same power output they should sound the same.
if two amps sound different one is broken, or just really shitty to begin with.
the quality in sound can vary from amp to amp...depending on the signal to noise ...thd......damping factor ...efficency....etc. ....don't expect any better SQ out of name brand entry level amps...if you are seeking true SQ and want new it will cost...most cheaper amps will give you decent SQ I'd look into something about 100 x 4 so you have good headroom....
You know, I want a amp better than this zxi 4406. I ain't looking into a sq system just a good am p that will last. Would 100rms be to much for my mb quart discus speakers? I am going active to
no such thing as to much power. i have 5 times the rms ratting on tap for my speakers. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nismofreak
VIP *****es
Nismofreak
ATL
2critical
