Splicing into existing wires...
beckSHO
Okay, so is there an easy way to do this? I know of these connectors that allow you to splice one wire into an existing wire, but I don't know how to use it. I tried searching and couldn't find anything. Please help me out here guys. Thanks.
scotch-locks. you place both wires into it and with pliers squeeze the the two halves together. not my preferred way of splicing wires. not as good of an electrical connection as soldering or butt splices.
Okay, cool. Now, I need to splice into the following wires. I have no harness, and don't tell me to go get one, this is a custom install. Now here are the wires I need to know:
Constant Battery- Yellow?
Ground- Obviously black
Accessory/Switched power- I have no idea on this one.....
I believe that's it. I'm installing my head unit in my 97 Taurus SHO. Can't just use a dash kit because of the Electronic Climate Controls.
Thanks guys.
Well, i found out which wires I had to tap into. Constant power is green/yellow, switched is yellow/black, and I ground the deck to a metal peice under the dash. However, I hooked everything up, but the deck won't turn on. I used t-taps for the connections, could this be why? I will try a different way of connecting it, hopefull it works.
----//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif ponder the following quotes.....
and never use t-taps.
strip, solder and tape / heat shrink tubing
x2
I hate t-taps
X 3, 4, 5, 6, and so on!
this is NOT A RELIABLE CONNECTION !
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Okay, so I took off the t-taps, and replaced with some butt connectors. But the darn thing STILL won't turn on. I checked my ground, that's not it. I hooked the constant power into the green/yellow wire. And I hooked the switched power into the yellow/black wire. That's all I need to hook up for the darn thing to turn on, right? Help me please....
you probably have no idea what wires ur even tapping into;
it's like ur just blindly tapping into random wires hoping for the best
Okay, if you're so smart, tell me what wires to tap into. While you're at it, correct the wiring diagram I looked at.
beckSHO
beckSHO
Michigan
beckSHO
