please help asap
THXdts
hey guys. I recent just installed everything in my truck. sub etc. I just hooked it all up. I turn on my truck and nothing. I look on the amp to see if the little power light is light up..nothing.I am pretty sure I have everything right. Any help guys? Thanks. I refuse to go to bed tonight without htis working lol.
****T IT. There was a wire in between them..which I thoguht u were supposed to take off. So I took it off. Now what? How can I reconnet it?
I had a set of RCA's where the remote turn on lead is in between them. I took the rca's apart like an idio.t I still have the remote turn on lead wire. How can I hook this back up? There is a remote part on my amp..but not part where I can just stick it in my hu. Thanks
yea, thats your problem, the remote turn on lead from the back off your headunit to the amp, its just a signal to turn the amp on when the radio turns on
just connect the wire you tore off to the remote input of the amp and the blue wire coming out of the back of your HU
connect the remote wire to the remote wire on your deck and the remote wire terminal on your amp.
the remote wire on the back of your head unit is the blue wire with white stripe most likely, just connect em together
sounds like your problem is solved, now you just need to do it
THXdts
THXdts
Maryland
Lckmyblls
