spl motor/ custom woofer help
  • 2
IbSlamn
Alabama
i have the motor of my old spl 15 in the pic below. ive seen a few custom woofers with the motor. and i was wondering how i know what basket i can use with the motor and what recone because im wanting to build a 10 out of the motor thanks
looks to be a 4" coil woofer. i would NOT build a 10" sub with a 4" coil because of the spiders diameter would be too small. 9.250" would be the min spider diameter i would use with a 4" coil or you will have problems...
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
IbSlamn
IbSlamn
Alabama
SPLaudio
