specific big 3
blabo219
I am doing the big 3 by myself and i dont know a whole lot about the rest of the car so if anyone can help me here, are the steps in the sticky pretty much eash to follow for any car?
and if anyone has pics of a 1998 oldsmobile cutlass or 1998 chevy malibu of the wires that would be amazing
It's the same concept for pretty much every car. Some cars (Lincoln LS, Olds Aurora, Cadillac Deville) have the battery in different spots, so it makes for longer runs.
yep just basic car electric system **** pretty much. its always a good idea to learn 12 volt sytems before getting into car audio and ****. its all very easy
My battery is like the complete opposite side so would i be able to run that wire like straight across the top? and just tie it down
also, all of the cables are being replaced right? as in there are already smaller ones there for all 3
oh jeez. if you don't know what youre doing, you probably shouldnt do it.
With that said, Look for your - batt terminal to go to the frame/chassis. You want to replace that wire.
Look for the alternator wire going from the alt to the + terminal of the battery. Replace that.
Look for a wire going from your frame/chassis to your engine/transmission. Replace that.
You have done the big 3.
X2
Couldn't have said it better!
Dont replace any wires. Add these wires to you stock wiring. I repeat dont remove any of your stock wiring.
Lets hear your reasoning behind this while keeping in mind that the new wire is more than capable of handling even say 100 amps more than the maximum that the car requires on the heaviest load.
I know where the first 2 are. Idk about the third and is there any order I have to go in?
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
blabo219
blabo219
Battle Creek, Michigan
Crownvicon28s
    May 16, 2024
    May 16, 2024
