cody89
Ok. i own a 1999 Plymouth Voyager. I have had the factory radio in it for some time and everything in the van worked. I took it out to replace it with a aftermarket cd player. once i took the factory radio out some problems started. I couldnt lock the doors with the key off. i couldnt turn the lights on with the key off and etc. so i tried hooking up the aftermarket cd player up to see if it will complete a circuit or something and well i bought a little cdplayer installation kit from wal mart and hooked up all the wires like it should and tried it... nothing worked. so i ended up having to jump the RED and the YELLOW power wires together.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif so something is wrong with either the red or yellow wire. but so far i have the radio on. but in the van the only speakers that work are the back two so i hook them up and it will play. i wrap electrical tape around the wires and then push the cd player back in and it stops. so i have to take the cd player out. turn the key off. unhook the speaker wires and then hook them back up. or sometimes i can just make them touch and they will come back on. but when i dont have the cd player pushed in or wrapped up i try to change it from cd to fm and then the speakers stop playing so i have to unhook them and turn the key off or touch them and they might work. was wondering why this is? ive tried using a different speaker and hooking it straight up to the cd player and it does the same thing. could it be the cd player or maybe some wire that isnt hooked up correctly?
