Speakers died for no reason?
SGSeeker
SO I've had some Aurum Cantus AC-180F1's (http://www.parts-express.com/pe/showdetl.cfm?Partnumber=296-412) running for a year but somewhere in there, the car had a huge drivetrain conversion so it was off the road for awhile. Some time last year the speakers just quit working - the both of them. There is no resistance on either speaker so obviously the voice coil is messed up. Being 8 ohm, I had ~70 watts max going to each speaker and crossover was set to 125hz.
Anyone have any ideas on why the **** things decided to fry themselves?
Sounds like you set it up wrong.
They lasted a long time though. Have you checked the wiring to make sure nothing corroded and the wires are all good.
I believe it was 100hz - it was a year and a half ago when I adjusted it. Maybe it was higher, who knows. I've got 50, 80, 100, 250, 500, and 1khz test tones on there. Wouldn't setting it up at a frequency too low cause something producing higher frequencies to be quieter? Anyways, the speakers were never much louder than the "tweeters" (3 1/2" 2-way speakers in the dash...) running off headunit power so I can't believe the gain was set over the top.
The wires were fine when I pulled the speakers out - other speakers fired up just fine. I haven't twisted them together to check the overall resistance but the ends were soldered onto the speakers rather than using quick disconnects. I solder everything I can when it comes to wiring.
Any chance that the amp was messed with? Were the settings still the same?
I would reset the gains using 1kz as well (when you get new speakers) Also, set the gains using 100 and then at 1kz and mark the amp so you can see the difference.
Also, did you set the gains with a different equation when you got the new amp?
The new amp isn't powering anything yet and not setup (gotta swap my eclipse sub amp out with the 1.1000 tomorrow). The amp wasn't messed with - it takes me an hour just to get to it myself with where it's mounted. I haven't touched the knob on the 2.150 yet so I can still power it up and find what it was set to.
Anyways, what's a good ~7" speaker in the $200-300 range? I'm looking for something that can do 100hz~2KHz. It's hard to search for information on independent drivers.
At least I only paid $100 for the AC's. Their suspension was too loose for my liking though.
I'm thinking of either going with the Seas W18EX001 that still appear to do better than most others, or try to stuff W22EX001's in there and go with a 3 way setup in the front in the end (8", 4", 1"). These 8" 8ohm drivers seem like they'd enjoy receiving the power I've got to offer for the frontstage.
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
246
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
200
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
371
SGSeeker
SGSeeker
Vancouver, WA
edzy
