speaker wiring
um correct me if im wrong but i take it you would wire it regularly like it would be mounted in the box. but i have also heard to switch the +'s and -'s around on the sub. thats my 2 cents.
now when you talk about reversing it do you mean switch the postive feed to the negative and the negative to the positive or do i switch the rcas goin into the amp
All it changes is the direction the speaker cone will move. so the inverted one will move down when the other one moves up and since the one is inverted they will both move up at the same time. If you would have them both normally installed and you would switch one speakers polarity they would both move in opposite direction which will will cause the sound waves comming from both speakers to cancel each other out which will bring down your sound volume (even cancelled out completely when your sitting in just the right spot, no matter how lout you crank up the volume) This is the only reason why you have to carefully check the speakers polarity when hooking up a system inversed polarity will not cause any harm to the speaker
so i jsut switch the positive and the negative around on the sub well what about the littler connectors to the voice coils that is on the back of the sub
Huh?
I think you're trying to make it harder than it is. When you invert the sub, just switch the wires around that connect to the sub.
couagajl99
couagajl99
Coshocton, OH
squeak9798
