Speaker Whistling
xKronicx
Hey, I just hooked up my amp and sub. And everything sounds good but when i turn on the car the speaker will start to make a whistling sound. And when i go it will start to make a higher pitch sound like the motor. I am wondering whats the problem? I am using the car battery for my 12v source. Could it be the wire are not thick enough? Because it works fine when the car is not on.
no //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
then who? i see no human being on any ava/pics
back to topic... getting better ground for my headunit usually make the whine go away. That was the case until i added an epic-160 in my dash. Now i'm getting the whine back... every amps are grounded to the rear batt neg terminal with the shortest wire possible
sometime i don't even ear it... other times it annoys me. I think it got something to do with the weather //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Well i grounded my amp and moved the RCA from the power cord.. That help out alittle but i still get the whistling sound when i have the radio volume on low. So i am thinking the wires are too thin.. Could that be the problem?
no, why don't you have change the headunit ground //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
xKronicx
xKronicx
Lawrenceville,GA
jdawg
