Speaker Whine.
It might be your 860 as they are notorious for noise problems. I would switch out the 860 and see if the whine goes away.
if you read a few posts up, it is not his headunit.
Your amp might also be damaged.
I'd say try finding a different ground. I would think the seatbelt bolt would work, but try a new location to eliminate that problem.
That's what I would do first. Good grounding spot, sanded down to bare metal, blah blah blah.
As for crossover points, like said, set it to what sounds best to you...
hmm i dunno if you recall but i had the same problem. i asked this question over at ECA and the poster named abmolech had some real technical shiet. check out the thread, http://forum.elitecaraudio.com/showthread.php?threadid=124022. maybe that can you give some ideas or you post on that thread and he'll help you out.
as for my situation, i just set my gains correctly with a DMM and alternator whine is gone!
yeah, in your case it was just too much high of a gain.
I had an old school amp that would wine no matter what, but when I grounded the actual chasis of the amp itself too, it got better. Might be something to try.
chinny
Banned
chinny
Miami Dade
chinny
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
