Speaker Weather Proofing
tracyrick
Limited035
I keep thinking about this but no one seems to fully address the issue.
Car is a Subaru Impreza. Question is, does water enter the inside of car doors from outside? If so, what part insides gets affected? Should I be wrapping some type of baffle around the back of my speaker?
My speakers are installed in the normal way. Can water enter in between the most external panel and the first internal panel where the speaker is mounted to?
If it does, I suppose my speaker magnet area is exposed to this. There are also vents around the magnet that open up to the inside of the speaker.
i've never had a problem. i'm not sure what the strips on both sides of the window are called. the felt type stuff that keeps the space on both sides of the window covered. anyway, i doubt much water could get in there, unless you hose down the inside panel.//content.invisioncic.com/y282845/emoticons/dont.gif.ed5870f9483b695f9745036963f41c24.gif
had this problem in my car, i figured i just had a leaky door and didn't feel like pulling off all the sound deadening and figuring out where the leak was...
so kickpanels for me it is. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
make sure the plastic seal thing on the outside of the window actually works, that keeps water from going into the door, oh and you can always get a mdf speaker baffle...
You'll go thru as much trouble to find and seal a leak as you would to build kicks
plus you dont want to seal the doors completely anyways, water will pool in there
May as well spend a couple of extra hours and build kicks, or door pods
CT
tracyrick
Limited035
tracyrick
Longmont, Colorado
danz24
