speaker wattage
blackhawk911
CT
I am looking to get new speakers cuz the ones I have now are blown, I just have a question about the wattage for the new speakers. On my factory speakers there 20w nom and 40w max. What does 20w NOM mean? Does that mean the wattage that the speakers needs to run on, I dont understand.
throw that peak number out the window, only pay attention to rms. rms is what they are meant to be played at. max means nothing. when you buy speakers find an amp that puts out power similar to their rms
20 watts rms is what the company has rated it for. after that you will prolly start hearing distortion. and once you get to a point they will stop getting loud and jus sound like poop. basically you wanna match the rms of the head unit(or amp) to the rms of the speaker without going to far over.
The 20 watts RMS is how much power they can handle continuously. The PEAK power is how much they can handle for a brief second or so, like on a hard bass note or powerful loud burst of any musical instrument for example. Whether or not you blow them again depends on how much power you are feeding them. Are they on an amp or on just a deck??
Well my car comes stock with 2 amps, 1 for the front 2 speakers and 1 for the back 2 speakers. When I buy the speakers I am getting a new HU, 2 subs, and an amp for the subs. So thats why I was trying to stay near 20w rms because thats what the stock speakers are. Is this right?
see I wasnt planning on getting new speakers untill I found out that 1 was blown and the others were in bad shape. so this is why Im looking for speakers. I was just planning on getting 2 pairs that worked with the stock amps and that was the same size. this is why im asking about the wattage so that i can get it right so that I dont blow them. So seeing that my stock speakers are 20w RMS should I stay at 20W and get a higher peak or get something with higher RMS?
You can go higher on the RMS, it won't hurt anything.
Did the factory speakers say what ohm load they are?? Most factory speakers are a higher than average ohm load, like around 8 or 10 or 12 ohms. Almost EVERY aftermarket speaker will be 4 ohms. That means that the amps would push a lot more power when turned to the same volume level as before and if they aren't built for it, then they wouldn't last, the amps I mean.
I'd bypass the factory amps and either run new speakers on just the deck, or put them on a new, nicer amp. Also ,depending on the size of the speakers you are replacing, it's going to be difficult to find speakers in the 20 watt RMS range. Most will be 40 RMS or higher, but that is not a problem. Don't try to look for speakers that only take 20 watts. Also PEAK wattage means next to nothing. Only comes into play if you were putting a 100 watt peak speaker on a 500 watt peak amp. Not likely you'll do that.
yup. your gonna hate it when the subs drown out the speakers.
blackhawk911
blackhawk911
CT
blackhawk911
