Speaker Help
Okay. As far as amp wires, are you referring to the speaker outputs on the amp? You can wire your amp to the 6.5 speaker (positive to positive... negative to neg...)If you have a numerous speakers all wired into a single positive and negative speaker cable then you need to check the impedance and make sure it is in your amp's specs. Just need more specific info to help you.
radrashad
radrashad
Bountiful
lionfamlee
