Speaker help with amp plz
farmerehsan
144.6 db
ok im redoing alot of things...
need help on this..
i am running 4 speakers to a 2 channel amp and am thinkin of going with the apline v12 mrv-f300 4 channel
the 2 channel im running now is the JL audio e2150
the speakers i have are:
6.5 (2) are tr650-cwi
and
2 6x9 Model # T6.9F3 3 way speaker
WOULD IT be louder if i went with that 4 channel amp?
Hi,
I think your running your speakers at 2ohm mode of JL amp.. and get 75w total per channel (150w for both).... if you go with alpine you will use each speaker per channel so you amplifier will work on 4 ohm mode ... which makes aproximetly 30w per channel (120w total) ...
In conclusion ... I thing you should stay with JL ...which is also better amp in compare to alpine f300
farmerehsan
144.6 db
farmerehsan
Tampa
farmerehsan
vegang
vegang
