speaker help plz
bacista88
i have some coaxial speakers now from boss. and they **** i was wondering if i should go with some components in the front and back or just the front. im really confused. and which ones r better coaxial or component plllzzzzzz help me
Components are better. Rears are not really necessary. If you insist on rears buy coaxes for the rears.
Budget your purchase as follows:
Front components 80%
Rear coaxials 20%
i had a sub sub hooked up and then i took it out so i can replace my speakers cuz my box took to much room. so should i and another amp? and if i do that should i run the amp to all the speakers or just the back to.
Ok, I'm assuming you have an amp for your sub already. If you want to add front and rear speakers then I would suggest adding a 4 channel amp. Then you could let your sub amp power the sub only. If you just want to add front speakers you would only need a 2 channel.
My suggestion for a more cost effective solution would be the following:
Buy a set of nice components you can afford.
Buy a 4 channel amp within your budget
Wait on the rear speakers for now and if you find you still really want them you can add a pair of rear speakers down the line you will have the channels on your amp available for them.
For now you can bridge that 4 channel down to 2 channels and run just your front components. If your components are good enough you may find you no longer need rears. Thats what happened to me a long time ago. I eventually found that I was no longer missing rear speakers.
bacista88
bacista88
boston
adam71
