06goat 10+ year member bumpin bluegrass 1,873 32 Michigan Mar 10, 2011 #1 Re-aligning my top plate on an old sub, what kinda adhesive do I use? like a two part epoxy? TIA Click to read more...
S SPLaudio 5,000+ posts CarAudio.com Veteran 6,745 60 upstate ny Mar 11, 2011 #4 i use 2 ton 5min epoxy. if you have never done it before i wouldnt try it. you have to totally remove the top plate and clean all the old glue off the top plate and top mag...
OP 06goat 10+ year member bumpin bluegrass 1,873 32 Michigan Mar 13, 2011 Thread Starter #5 i use 2 ton 5min epoxy. if you have never done it before i wouldnt try it. you have to totally remove the top plate and clean all the old glue off the top plate and top mag... Click to expand... Top plate is already off, glue is cleaned off, and i finished a spacer in the lathe the other day so it will be centered. Thanks tho Ill glue it down tomarrow
