Soundstream Rubicon
I had the 2500. Little bit over rated and it's kind of a power hog. Besides that they are pretty good amps, you can run them at a pretty low impedance.
I was looking at them b/c of the lower price tag. Would I need a extra batt. to run the 1600.1 since they use alot of power?
Depends what kinda vehicle you have. You might be able to get away with running it on stock electrical if you have a larger alternator.
also the big 3 is a must. the more you can do to your electrical the better man anyway. i'd still do a extra batt also. what size alt you have?
I love the rubicon line, I sell a lot of them. They are under rated on power and pretty reliable. check outFacebook
for my last install.
Clean install! Do they sound good are they power hogs? Which is the better soundstream amp Rubicon, Tarantula or D-Tower?
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
t-scene
t-scene
Abingdon VA
t-scene
    May 31, 2024
    May 24, 2024
