Sold SoundQuest Battery Terminals
wgsj_fortvalley
Registered User
1 0ga 1 4ga 2 8ga.
$6.95each PM me for shipping
I've never seen a battery terminal with inputs and outputs
in and out is the same, considering you can use the terminals to take in wire, or put out wire
so because something has 2 1/0 inputs means i cant use one of them to put out wire? hmm... i didnt know that...
also if you wanna get technical, the battery terminal above is considered a distribution block then, what if someone has the 1/0 taking in 1/0 from a big three then using the 4 gauge for a 4f run to the back? therefor it is acting as a distribution block because it is distributing the power throughout
ok well why the fuck do you guys care? do i need to rephrase the question for you dumb fucks?
ok here we go:
do you have any of these that have 2 holes that 1/0 wire will be able to fit into?
ok here we go:
the only ones with 2 0ga on them are the stinger pro and theyre really expensive.
wgsj_fortvalley
Registered User
wgsj_fortvalley
Crawford County, GA
wgsj_fortvalley
