SoundQubed 1200D
*Ace*
SoundQubed 1200D
Used, works 100%. Condition is 8.5/10
Model Q1-1200D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 40Amp X 3 (Linked 240 Amp)
Output Power 14.4V @ 1% THD 510X1 @ 4 ohm,870X1 @ 2 ohm,1200X1 @1 ohm
Output Power 14.4V @ 5% THD 1470X1 @ 1 ohm
Dimensions 12.75"(L)x9.27"(W)x2.35"(H)
$225 + shipping. Shipped via FedEx.
Of course its as solid puts out every penny and quite efficiently to my surprise
kinda figured as much. In my setup, final impedance at the amp would be 2 ohms so according to their site 870 watts. That would be sufficient for my 2 RF P3 12's id think. Your thoughts? It just seems too good to be true for two hundred and fifteen bucks, ya know what i mean?
also, i guess if its not enough, i could just rewire the subs to 1 ohm each and strap 2 together...
If its in the proper box yea, theyll get movig not adequatley but theyll move. Im running an hx2 12 on 400w and it moves nicely for only 400w. In running the q-1200 on am hds312 and it moves nicely aswell
*Ace*
*Ace*
Las Vegas, NV
C1500martin
